MEP805B Engine Control Prime & Run position
Raptor01
Madera CA
Does anyone know what happens when the generator control switch is placed in "Prime & Run" position prior to starting the generator? Should I hear something start to run like a fuel priming pump? Couldn't find a description of this switch position function in any of the Tech Manuals.
Raptor01
Madera CA
Yes, you should hear the electric fuel pump come on. It should slow down/stop when it has primed the system.
Thanks for replying. I don't hear anything come on. Where is the electric fuel pump? Can you point me to a figure in the tech manual? I need to make sure it is getting voltage.
peapvp
1,227
Basehor, KS
Is your Master Switch S3 in On or Off Position when you place the Engine Control Switch S1 in "Run &Prime" ?
Guyfang
24,042
Burgkunstadt, Germany
Wait!!!!!!!!!!!!! No you should NOT hear anything. Sorry, I was helping someone with an MEP-005A, and just kept thinking about a different gen set. Sorry, one hundred times. All you have is a hand operated primer hand pump. There is an AUX electric fuel pump. But no other electric fuel pump.
Tell us what problems you are having.
