MEP805B Engine Control Prime & Run position
Raptor01
Madera CA
Does anyone know what happens when the generator control switch is placed in "Prime & Run" position prior to starting the generator? Should I hear something start to run like a fuel priming pump? Couldn't find a description of this switch position function in any of the Tech Manuals.
Raptor01
Madera CA
Yes, you should hear the electric fuel pump come on. It should slow down/stop when it has primed the system.
Thanks for replying. I don't hear anything come on. Where is the electric fuel pump? Can you point me to a figure in the tech manual? I need to make sure it is getting voltage.
peapvp
1,227
Basehor, KS
Is your Master Switch S3 in On or Off Position when you place the Engine Control Switch S1 in "Run &Prime" ?
Guyfang
24,053
Burgkunstadt, Germany
Wait!!!!!!!!!!!!! No you should NOT hear anything. Sorry, I was helping someone with an MEP-005A, and just kept thinking about a different gen set. Sorry, one hundred times. All you have is a hand operated primer hand pump. There is an AUX electric fuel pump. But no other electric fuel pump.
Tell us what problems you are having.
Raptor01
Madera CA
Hello.
Hello, Master Switch is in the On position. BTW, the generator starts and runs fine. Just wondering what happens when the switch is in the Prime & Run position. The TMs just say to place the switch in this position. It does not tell you what to check for.
Raptor01
Madera CA
Thank you. The generator runs fine after a fuel pump rebuild ($1500 in California). Just wondering what happens when the switch is in the Prime & Run position. The TMs just say to place the switch in this position. It does not tell you what to check for.
Guyfang
24,053
The prime and run position.
With the engine off, all the run circuits are energized. It doesn't prime anything, as there is no electric fuel pump.
With the engine ON and running, All run circuits are energized, and the set operates.
This position is where the S1 will spring back to, after you start the set, it comes up, makes power, and you let go of the S1. This is the normal position for S1 to be in. The only other time the S1 is in another position during operation is the AUX/Run position. That's used for running off a separate fuel supply.
Raptor01
Madera CA
That clears it up for me. I assumed it was priming something because it is labeled "Prime & Run". Like they say, assuming makes an ass out of you and me:)
