MEP805B Engine Control Prime & Run position
Guyfang
27,146
Burgkunstadt, Germany
The audience of this manual is an 18 year old soldier or airman. Not a lot of common sense or experience there.
You are so wrong there. There is plenty of common sense in the young soldiers. And experience? Maybe not in generators, but a young soldier may very well have built a fast car, or be a farm boy. And Farm Boys, by and large can fix stuff.
The big difference between them and you is this. You do not have a MSG or CW3 standing behind you, and he says, "Take this TM back to the barracks with you. YOU WILL READ, chapter 1-4. In the morning, I am going to ask you 10 questions. Should you not be able to answer at least 9 of them correctly, you will be digging several large holes after duty time, tomorrow." My favorite "Teaching method" was having them drive 9 foot ground rods, and then pulling them back out of the ground. Normally, 2 doses of that medicine was all it took.
peapvp
1,679
Basehor, KS
Did not know that the Aux pump works will the fuel level switch. My Fuel Level gauge is inop. Troubleshot it down to a bad sender, Does anyone know of an aftermarket suitable substitute for the fuel sender (TM 9-6115-671-24P, Figure 11, Item 30)?
Any one which fits and has a ohm range as shown below
