MEP806A Stanadyne injector pump stuck
sfus2645
9
Miami, Florida
Hello, I have a 1995 MEP006A with a John Deere engine. I need to rebuild the fuel injection pump. I have try everything I can think off to remove that pump, I even built a tool with a 2 ton hydraulic bottle jack, and applied at least two tons of pressure on it, and it doesn't move. Any ideas??
2Pbfeet
816
Mt. Hamilton, CA
+1 on heat. It is your friend here, but a gear puller is probably the tool that you want.
Did you get the pump timed to the engine already? It really helps reinstallation. Here's a video of a similar Stanadyne removal from a JD engine;
PM if you need a rebuilder. I know a good one in SC.
All the best,
2Pbfeet
Guyfang
24,519
Burgkunstadt, Germany
This is not, according to SFUS, an MEP-806A. Its an MEP-006A. Different animals. I think maybe SFUS wrote the wrong model number, or someone put a JD engine in a MEP-006A
sfus2645
9
Miami, Florida
I installed the new pump, it starts perfect.
Now I have a new problem, under voltage.
I replaced the fuse next to the voltage regulator just in case but it didn't solve the problem.
Any Ideas
Scoobyshep
1,579
Florida
Any Ideas
Under voltage light or is the voltage actually low?
kloppk
3,603
Pepperell, Massachusetts
Does the Voltmeter and freq meter show good voltage and frequency while you have S1 in START and the engine running?
If so use the AC VR test procedure called out in the -24 TM. Use the correct procedure since your generator may have a Libby or a TRC VR. Different procedures for the two of them.
sfus2645
9
Miami, Florida
I did the test specified on the TM
on H instead of 8 VDC I got 10-11 VDC
on J instead of 67.5 to 90 VAC I got 1.5 VAC
on L instead of 108 to 132 VAc I got 11 to 12 VAC
