All,
I have a NEW MEP831A which is showing 6 hours. Ive been through the manual with Crank No Start troubleshooting and everything seems ok.
- Im powering the Genset from a 24v Slave cable from a HMMWV..
- Turns over vigorously
- Electric Fuel fump is running..
- Checked for fuel to the Engine from the electrical fuel pump into a bottle to be sure its getting fuel.
- loosened the hardline from the mechanical fuel pump on engine to see if it needed to be bled, but didn't see any fuel coming out at all
- remove the hardline from the fuel pump to the injector to see if fuel is making it through the fuel pump on the engine, and no fuel
- The Fuel Control Arm is moving and its set to start..
should I be seeing a squirt of fuel from the mechanical pump on cranking... seems to me I should..
thoughts?
thoughts?
