MEP831A- Have Question ON Starter Operation
camoken
New Boston, NH
This is my first time posting, so I hope I don't screw it up too bad...
I just bought an MEP831A. Everything seems to work fine except when I start it, the engine won't fire while I
hold the toggle in the start position, no matter how long, but will fire as soon as I let it go back to run.
Any Suggestions? (I know, at least it starts and runs.)
AfghanVeteran2010
20
Odessa/Texas
Mine used to act similar to what your describing, take a look at the actuator when you are trying to starting it. Mine would not lift off of magnet and when i would let off the starter it would bounce off of magnet. Hopefully this helps, pictures/video speak a million words. Do you have a TM for the set?
camoken
New Boston, NH
Thanks for responding. I do have a TM and I understand what you are saying. I will take a look, hopefully tomorrow.How did you fix it? adjustment?
I am new to the MEP831A, so I'm not all that familiar with it yet, but I'm reading and learning... I will read about it before I tweak anything.
I am also in the middle of removing/ rebuilding injection pump on my MEP002A... Gotta keep busy to stay outta trouble.. Thank You For The Help, I'll let you know what I find..
AfghanVeteran2010
20
Odessa/Texas
On my unit it was caused by the mechanical governor speed control knob coming lose and shifted closer to the stop position. I fixed it by placing the mechanical governor speed control knob in START position and tightened. Sorry I left this out of last post.
camoken
New Boston, NH
Afghan Vet 2010, Thanks for your input, you were correct. The magnet was hanging closed just like you said. On one start just the engine bouncing separated the magnets and it fired as normal. I'll go over the procedure to adjust the linkage. Thanks again. I wish they were all that easy....
Guyfang
23,030
Burgkunstadt, Germany
Take your time doing the readjustment! Better to adjust it several times, just a hair at a time, testing in between. It can be a PITA.
camoken
New Boston, NH
Guyfang, Thanks for the advice. I hope to play with it next week. I am still working on my IP from my MEP002A. I'd like to finish that one before I look at the 831.This is my first attempt at rebuilding an IP and I have spent many days and evenings reading the posts about outer members having the same problems and questions. It is amazing how much information can be found on this site thanks to members like you..
Guyfang
23,030
I just posted in the manuals upload section simple instructions on how to setup and adjust the governor for the MEP-831A. I think its easier to follow then the TM, and if you print it out, (its one page) easier to look at then the TM or computer screen. Got it from a "friend". Thanks dude!
camoken
New Boston, NH
Guyfang, I can't seem to find the governor adjustment procedure. I looked under TECHNICAL MANUALS and found the other three MEP831A manuals you posted. Am I looking in the wrong place?
