- 2,895
- 7,031
- 113
- West greenwich/RI
Hello guys, I have a question regarding an MEP-003A that I'm working on.
It is a machine with 6 original hours on it, has been sitting a very long time. I purchased 2 of them on a M1061 trailer from a nearby municipality.
I went through the machine doing all the regular pre-start stuff, flush fluids, change filters, flush the tank, check the IP etc.
I got it started but I think the injection timing is wrong. ( Not from anything I did )
It starts very difficult and slowly, takes a lot of pre-heating even with it hot outside.
Once it starts it does not come right up to speed, it slowly builds RPMs over the course of a minute or 2.
While running it is billowing white / gray smoke , mainly from cyl.4 and spitting raw fuel out of that cylinder, but also getting very hot on cyl 4. I've checked, cleaned and set the pop pressure on all 4 injectors, tested compression ( well over 300Psi on all cyl. ) and checked the valve lash.
So far I have only found that the Delivery valve seal is virtually gone... just little chunks of plastic left.
To me ( based on reading other posts here ) it sounds like the IP timing is somehow wrong, so I wanted to ask you guys: If the plunger guide has cracked, causing it to skip on the plunger, but is still intact enough to turn the plunger but its now out of time, I assume I will notice a problem if I do the static pump timing test to see if fuel flow stops at the PC mark?
Or does anyone have experience with a destroyed delivery valve seal to know what ill effects that would cause?
My plan is to do the timing test and pull off the pump if anything looks wrong, but wondering if you think it would be worth while to buy or scavenge a delivery valve seal from another machine and try it before taking the pump out, if that could be causing the problem?
