Michelin 16 X 20.00 XZL on 2.5 Ton Axels
gringeltaube
Staff Member
2,655
Montevideo/Uruguay
G,
I am going to get rid of the split rims and build-up a set of bolt together bead seat rims. .............................. Do you see any compatibility problems with the stock split rim bead size and the 16 XZL's?............................
Pete
Not at all, although the stock M35 wheel has a bead flange (or "horn") height of little over 1-1/2", vs the ones on any industrial 10" rim, which are 2".
Compare specs in chart & diagram, below....
G.
