mid recovery question M105A2
ordkhntr
Oregon
Hubs are getting warm after about 40 miles at 50mph. I read the TM and it says to pull the tire obviously to service the bearings. I can't get the nuts to budge with the breaker bar , and yep. I know the left side is reverse threads. Can i got to the outer bearings without pulling the tire?
Thanks
RJ
Ps, thank God for smart phones :)
doghead
4 Star General /Moderator
1,191
NY
How far do you have to go?
How warm? Do you think you will actually get burned if you hold your hand on it?
goldneagle
1,465
Slidell, LA
Why not drive it slowly to a service center or tire shop on route. (a truck stop would have large air gun to do the work)
doghead
1,191
NY
How much farther do you need to go?
If the water literally makes a noise and steam from the heat, it is too hot to continue.
doghead
1,191
NY
Are you 100% sure it's not the brakes dragging? Is the drum that hot too?
ordkhntr
Oregon
150 miles. water just slowly steams off. No noise. Not spitting grease. Just warmer than any of my boat trailers have gotten. Im just going to take my time and hope for a shop on the way.
Would it even help to get grease into only one side?
doghead
1,191
NY
Carry on, and check occasionally.
ordkhntr
Oregon
Good thing is i am not in a hurry. Got a thermous of coffee and my ham radio......oh and a sleeping bag. :)
Thanks for all the reply, they help to settle the nerves a bit.
silverstate55
Unemployable
2,127
1,086
UT
Open the drain valve on the air reservoir (if equipped), that will relieve air pressure from building up & applying brakes.
Older M105 hubs have 8 cap screws (or bolts) holding them in place; newer ones have 3 phillips-head screws holding them secure. You can remove these hubcaps to have a look into the outer bearings.
m16ty
227
Dickson,TN
You can pull the hub without removing the tire. It's a little hard to deal with because of the extra weight of the tire but it can be done.
ordkhntr
Oregon
45 miles to go, taking my last break. Just trying to be extra careful. An extra 15 minutes here on the end of the trip won't kill me......but if i lot a hub......well....wouldn't kill me but it sure would really stink. :)
ordkhntr
Oregon
Well, made it home ok. Now its time to start cleaning it up. Think Ill start with the wheel bearings :)
and here is a pic of my new ugly beast......gotta say, not bad for $120.
dmetalmiki
2,035
London England
(you can(when you arrive home)) Undo the 6 bolts on the Axle Flange. and remove the Half shaft. Then you could see the bearings and grease status, but reoving the wheel this way would be very difficult and unwieldy without a wheel support tool. A small point , removing the tire is Not the same as removing the wheel AND tire (as) you have to remove the Tire and wheel rim to remove the tire. (properly).
DANGER>>DO NOT DO THIS, BUT
We once saw a mechenic remove some of the inner combat retaining bolts on a British truck and the tire..!removed itself!
SCSG-G4
PSVB 3003
5,399
3,490
Lexington, South Carolina
If you are going to check the bearings, make sure you have an 8 sided 3 3/8 inch socket, either locally or from '319' here on the site - see his ad in the classifieds. You can get the nuts off with a screwdriver and a small mallet, but setting the correct load when re-assembling can be problematic.
