Military connector crimpers
ramdough
1,731
Austin, Texas
I cannot find my AF8 crimper….. never used it. Hate to buy another, then find mine.
I bought some of the m connectors to fix and modify my light harnesses.
Would this potentially be a cheaper alternative?
iCrimp Deutsch Solid Contacts Crimping Tool AWG 26-12 for Size 12,16,20 applicable to DT,DTP,DTM serie https://a.co/d/7BabT8k
Thoughts?
87cr250r
2,131
Rodeo, Ca
I use these and they work fine.
You could probably find similar units for half that price.
ramdough
1,731
Austin, Texas
I broke down and bought another af8 on eBay. Price was good enough.
On some of my connectors, just the rubber boot is garbage. Is it reasonable to just replace that or is that a royal PITA?
G744
4,116
Hidden Valley, Az
The boot over the male pin can be changed by removing the "C" washer by pulling the male pin thru, and then pulling the wire back out.
Slide the new boot on, reinstall the washer, and pull back.
A tiny drop of brake fluid will make things fit easier.
ramdough
1,731
Austin, Texas
Crimper came in today.
What setting do you all use for the pins and sockets (talking metal pin or metal socket parts not rubber boot etc )?
