Military trailer towing limits?
86M10086.2L
Long Island, New York
Whats the largest military trailer that can safely/reasonably be towed behind a M1008. I found a M416 trailer that's cheap that I might pick up, but I was a bit disapointed that its too small to fit a ATV in. Are there any larger trailers that can be used with a M1008? Or are you limited to the M416, M100 types. The M416 would still be cool for camping and stuff, but if something bigger can be used that would be great.
maddawg308
747
Front Royal, VA
A M1008 should have no problem towing a M116 3/4-ton generator trailer. Buy one without the gensets, install a couple ramps in the back, drive your ATV on and haul butt down the road!
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
I have towed a 25' gooseneck behind a 1985 1 ton (civy) chevy pickup with 3 dismantled truck bodies on the back with no issues what-ever from TX to WI. The only possible problem may be not enough motor if you have too big of a trailer and the 6.2.
AJMBLAZER
Paducah, KY
The M101 was the trailer meant to be towed behind it. They even changed the design to a more modern 8 lug axle so it could use the same wheels as the Dodge and Chevy CUCV's.
The M105 can be towed behind a CUCV but the trailer empty is pushing the limits so you can't really load it down at all.
The problem with military trailers is they are so much heavier than their civilian counterparts that you're potentially loosing capacity on the trailer by running out of towing ability with the vehicle. I've got a civilian trailer that can't weigh half what a M101 weighs but can easily haul just as much.
86M10086.2L
Well I grabbed the M416 I found. It's in good shape and the price was right. It needs a few things but they all do. The Quad still fits in the bed of the truck. So I may just shift the stuff from the truck bed to the trailer and keep the ATV in there during travel.
krick3tt
Denver, CO
It looks like it needs a spring over to get it to ride level with your truck.
Really not a big issue to put the axle under the springs except the parking brake attachment to the frame will need adjustment. Extend them with a plate.
Mine rides the same as before, when the springs were on bottom.
Morris
73 Pinzgauer, M416 trailer
86M10086.2L
I'm thinking on that, we'll see. Seems alot of Jeep and Landcruiser guys use these and the Canadian version trailers. Anyone have any idea where I can find military tail lights and mounting brakets for thetrailer? I'm not having much luck finding any. I'm already in the trailer section with the same info, just covering all the bases because you never know who has what.
