mill H-1 heater
redlight
Boston/mass
I am looking at a very used H-1 heater. Photos say it is gas powered. 400000 btu stock number 8200-3334-16 The stock number may not be correct. reg/sn 452052DJA2049 ID NO=AG2049<br><br>Has a single lead to a gas engine to drive the fan. it has a recoil starter on the motor. documents indicate T.O. 35E7-2-3-1 with the last pm completed 96311 I think that translate to March 11 1996. <br>Any info would be welcome.<br>Thanks<br>Redlight
Wire Fox
162
Indianapolis, Indiana
His model is very different than mine. Some of the core functionality may be the same, but the difference of engine means everything's different parts and different maintenance. It looks like that's one of the BT-400 models, but configured with a gas engine. Unfortunately, the BT-400s are configured with numerous options, so I can't tell you exactly maintenance manual you need to work on that model. If you can get some more details (what engine is in it, year of manufacture, or just some pictures), I might be able to help you figure this out. The bright side: the BT-400 series has a lot of manuals floating around out there. There's a good chance this model has one in circulation.
redlight
Boston/mass
Thank you all for the reply. I did not have full information as it was at an auction site. I did win the bidding war and I am going to pick it up today. I will post pictures once I get home.
Thanks again
redlight
Boston/mass
The unit is made by Herman Nelson. I brought it home yesterday and spent today cleaning out the mouse houses. The engine is free and takes a 2244 spark plug. I am soaking it in marvelIMG_3326.JPGIMG_3327.JPGIMG_3328.JPGIMG_3329.JPG mystery oil for a few days. I will attempt to start it next week. Any manual help would be appreciated.
Bruce
redlight
Boston/mass
It is very similar but not the same. Thank you so very much as it will help me get it working. I have spoken to the Herman Miller factory and they have a current issue gas heater as well as several diesel models. they are trying to find an old manual for the H=1 model.It does turn over but no engine spark, I do not know anything about magnetos but i will try my best to get it going. There seems to be good compression. The fuel tank is bone dry and the fuel filter inside looks like a string wrapped around a sleeve. I will be working on it Friday and will report progress and include pictures. When I attempt to start the heater, I plan on having the fire Department on scene and to start it away from house and garage.
Wire Fox
162
The fire department seems a bit excessive, but I'm guessing you guys are probably friends. I just keep around an extinguisher and only apply enough fuel for the testing operation I'm doing.
Sent from my Nokia 6.1 using Tapatalk
