Missing Primary Fuel Filter
DeucesWild11
12
Putnam County, NY
So I finally got around to changing my fuel filters and took off the primary. Looked inside the canister...nothing... looked back up at the truck...nothing.. No filter in sight.. So I went to the other two filters and thank God they were there. The secondary looked like it was sitting at the bottom of a lake as you can see in the pics.
Now, when driving locally I can't get up hills for s&*t. I average about 20 up a good hill. Not sure if all deuces are like that or if there is something holding mine back. It's bobbed but a non turbo. I was thinking if it is possible that the fuel lines between the tank and the secondary filter are gummed up? However there is pretty good pressure at the final filter and the fuel tank is pretty clean, I opened the drain on he bottom and took about a gallon of diesel out.. looked fine. I was thinking of taking out the fuel pump to inspect..
Any thoughts or is my Deuce just a dog like the rest of them. I do have nothing to compare it to.. Thanks!
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
That looks yummy, better than what mine looked like when I got it.
[media]http://www.youtube.com/watch?v=m90InQeoBUc[/media]
DieselBob
13
Arnold Maryland
Man that filter looks nasty. This might seem like a stupid question on a NA truck but do you have much smoke when pulling the hill ?. You might want to install a pyrometer and see if you can turn the fuel up and maybe get a little more power.
DeucesWild11
12
Putnam County, NY
Don't know about the smoke, haven't seen any from the cab.. I was thinking of turning it up but not before installing a pyrometer.. another think I need to educate myself on.. Thanks for the tip
197thhhc
15
Williamsburg, OHIO
The filter looked nasty. The engine should have decent power especially bobbed, you lost 3000 pounds from a regular deuce. Your fuel setting may be really off. Get a pyrometer and spend an afternoon cranking it up and you will be amazed at what you can get from these old engines. Good luck.
greg2560
Yoakum Texas
Looks like diesel algae to me drop the tank and take it to the car wash and clean it out.. And run some diesel additive to kill the algae..If diesel sits along time it will grow a type of algae.....The dinosaurs will come haunt you lol !!!! :jumpin:
dabtl
Denton, Texas
Mine looked similar. I replaced the stock filters with the jatonka spin on filters, including the primary.
I then got some bio killer and added it to the fuel tank. I was astounded at how much crap was in the primary filter after running it for some months.
1,127
We've had several that were missing the primary and one that had no oil filters in it!
DeucesWild11
12
Putnam County, NY
Thanks guys I'll try some bio killer and perhaps run some Stanadyne Blue or Total Power FPPF through it and see if that helps. When the weather gets warmer I do want to drop the tank and do a good cleaning. Too cold to be working on this kind of stuff.. I hate cold metal.. Anyway the wifey's got me building a new kitchen.. oh well this will take a back seat..
Clinto, **** that's even scarier.. no oil filters!!
