Mk48 Engine issues
tokarev
Safety Harbor Florida
Trying to figure out what the problem is with the 92 series detroit diesel in my Mk48. The Engine starts on the first flip of the switch. It seems to idle with a slight miss - in neutral the engine will rev up and seems normal. When shifted into gear especially forward and throttle is applied white smoke starts coming out the exhaust and there is no power. Also getting oil out the hot side of the turbo. Trying to get an idea of where to start looking for the fix. Thanks
Ford Mechanic
Edenton, NC
Just a shot in the dark but I would check the boost pressure in the intake manifold. The oil out of the hot side of the turbo, is it coming from the shaft seal or just blowing out with the exhaust?
