- 243
- 6
- 18
- Safety Harbor Florida
Have a question about the primer pump next to the filters on the MK48 - When you pump the primer it blows bubbles in the fuel filter bowl - Theres no real pressure on the pump as you work it. The reason for trying to use the primer pump is the engine wont start - it ran fine when it was delivered and then I let it sit for a couple weeks. Tried to start it - it acted like it wanted to start then nothing. On the door of the truck someone wrote "fuel leak" - I havent found one yet but it might explain it not wanting to start. We crawled all over it looking for a leak. Made sure the shutdown cable/solenoid wasnt stuck closed. Could we be leaking air into the system through the primer pump?
