mk48 night mare
wreckerman893
Possum Connoisseur
15,647
2,141
:tigger:
I went down to Blount Island in Fla with Ron and we put several of the MK-48's back together and loaded them for shipment. One person bought just the power unit and I had to load it up a steep ramp. When it hit center of gravity and dropped onto the deck of the trailer my O-ring tightened up to the point you couldn't have driven a needle past it with a 12 pound sledge hammer.:shock:
Artisan
229
CDA Idaho
:tigger:
Oh MAN I pray that is not coming from the voice of experience! ;-)
jcappeljr
27
Delta, PA.
mk48 fix 001.jpgmk48 fix 002.jpgMore tear down pics.**** what a MAJOR job this turned out to be.It really sux to tear apart such a beautiful machine with only 185 miles on it...
jcappeljr
27
Delta, PA.
I grabbed the input shaft on the old transfer case and it wiggles up and down about a quarter inch.The new transfer case is tight.
marchplumber
3,476
Peoria, Illinois
Strange, how can anything with that many hydraulic hoses operate with "battle damage" and still be mission capable? You have a task ahead of you. Sure she will be worth all your hard effort when you get her back together!
God bless
Tony
jcappeljr
27
Delta, PA.
mk48 trans lift 003.jpgmk48 trans lift 004.jpgmk48 trans lift 005.jpgmk48 trans lift 006.jpgmk48 trans lift 007.jpgmk48 trans lift 008.jpgmk48 trans lift 009.jpgmk48 trans lift 010.jpgmk48 trans lift 011.jpgWe pulled the transfer case today and reset the new one in.That was a big part of the job done.The mechanic noticed that the old transfer case paint was blistered above the input shaft,looks like it got real hot and fried the bearings or the lube pump went bad.there is a pic of it .
jcappeljr
27
Delta, PA.
That was my buddies girl friend.That was incentive to get the mechanics to work faster.She cooked them lunch on the grill.I told them lunch would be served after the transfer case was set..
Artisan
229
CDA Idaho
That sure is a fine lookin' trailer you have there John.
Are there more pics of that trailer? :grin:
...all kiddin' aside congrats, looks like you are "Over the Hill"
and on your way to success. Go slow, do it right, cross your tee's
and dot your eyes.
After this is all over will you do a T/C rebuild thread?
drician
Graham, WA
What a job! Good luck getting it back together, and I hope to see some videos of you cruising in it really soon.
