MKT-75A Fully Set Up Walk Around
wallew
Well, here you guys go. I FINALLY got my MKT-75A set up. Here's a video of what it looks like.
https://www.youtube.com/watch?v=CpQXUpmOqWY
Five of my support poles have either one or NO brackets to hold the side poles. I'm also missing one long side pole and one short side pole. I'm also missing the black part of the pole that screws in and out, allowing you to adjust tension of the part of the MKT that shades the walkway.
So, if any of you out there has these parts, PLEASE either PM me or send me an email. I want to make this one whole again.
SCSG-G4
PSVB 3003
3,218
Lexington, South Carolina
You don't need a second short pole, a ladder is suppose to go in that slot just for the cooks. Where you came up, there is a swing up table that I use for the plates and utensils, leaving more room for serving. You have the old style roof canopy poles, with the cast rings. The later style has welded rings and the keeper at the bottom is attached with setscrews, not welded. You may be able to use conduit to replace the missing side rail. HTH.
