- 2,115
- 674
- 113
- Orlando, FL
I recently did a brake job and repacked all wheel bearings front and back. I also replaced the hub seals on the rear axles.
The hubs on the rear axles are running what I consider too hot. After running down the highway at 50mph, the rear hubs are too hot to hold your hand on for 5 seconds. I put a little water on the hubs and it doesn't boil off, so they are less than 212 degrees; but the exact temperature is unknown. I read that bearing temps should not be more than 50 degrees above ambient temperature. Since it's been in the nineties here, that would make it almost 150 degrees. I don't know if you should be able to hold your hand on 150 degrees for 5 seconds. Maybe someone knows a rule of thumb for judging temperature.
The front hubs are cool to the touch. I adjusted all the bearings same way; the only difference is the rear hubs have outer grease seals that the front do not. The brakes aren't dragging since the drums themselves are not hot.
I've read the grease seals can make the hubs run hot. Question is; can the grease seals make that much heat? I also noticed after driving about 200 miles over the weekend the temperatures seemed lower. However, the last couple of miles I was only going about 35mph so that may account for the difference.
