More of My M108
rizzo
Port Huron, MI
Armada said:
Kevin, those are great pictures!
How goes the 5T engine swap?
the engine is in and mounted, drive shaft ordered, need to put the tune up parts on and set up the electrical. I am missing a air assist for the brakes, so I think I am going to bypass that for now just to get the brakes working on full manual. I should get the drive shaft (auto trans to 5ton T-case) this week. I need to install a air compessor from a ld-465 and get the air system plugged where the air assist used to be.
does anyone know where I can get an air assist and how much?
rizzo
Port Huron, MI
Armada said:
Is the 5t's air assist the same as the duece? I have one from a 2.5, a compressor too if you need it.
the air assist is not the same :( I do have a compressor though) thanks for the offer.
1,824
There have been many air packs on ebay lately for 5 tons. New ones and cheaper that deuce air packs. Check there!
