more room behind wheel m35a2 help?
m16ty
211
Dickson,TN
If you've got a spring seat you can replace it with a box seat. That will give you a little more room with the belly. Don't think it will help much with the leg room though.
kilness
Owatonna/Mn
Feel for ya buddy. I'm tall also 6'10" and wanted an M35a2 but had to get an a3 to be comfortable. I've heard guys cutting a coil out of the spring under the seat. Other than that its a 5 ton wheel and with that you would need power steering.
Pawnshop
23
Austin/Cedar Park Texas
I cut the back off the box seat so I could move my hips farther to the rear, so my long legs (and bum hip and size 13 boots) could all fit betwixt the seat and clutch pedal. I can take a photo for you tomorrow if you like.
Csm Davis
391
Hattiesburg, Mississippi
6'8"
I feel your pains but I thought the a3 was the same cab if not fill us in!
Cigarjoe
Greenwood, IN
I don't have a duece yet but I thought about cutting a few inches out of the steering column and shaft, and welding it back together. Has this been done or tried by anyone?
dmetalmiki
2,027
London England
no S/Wheel room cure
I got cheesed with the ridiculouse way the drivers postion is in these trucks,,sooooooo! |Take out the mounting bolts Re-Drill as high as you can lift the steering wheel and presto! Leg Room. and the ability to get at the pedals for mundane things like de-clutching and Stopping! its night snowing and cold but I tried to PIC the postion of the s/wheels in my deuce and 5 ton. good luck.
