more room behind wheel m35a2 help?
recon
verbank,ny
I had a similar problem when I got my M35. I took the back off the seat and found the foam was very hard and would not compress much. Wheel rubbed my belly (6'4 245). I replaced the foam with furniture grade foam from a fabric store. I used two layers and trimmed all the corners and reused the old cover. It now compresses enough so I clear the wheel and get more leg room for the pedals but still get some cushioning I also found the plywood under the seat was rotten and replaced that also.
Recon
Csm Davis
406
Hattiesburg, Mississippi
Will someone post more about moving the column up. At 6'8" and 345 lbs. I just open the door while shifting! No real problem with wheel hitting my belly just can't get my knee to clear wheel with door closed.
jbayer
10
St. Aug., FL/ McGrady, NC
The pedal shafts have notches in them that the bolt rides in. You have to take the bolt out, adjust the pedal shaft up, or down, line up a notch with the bolt hole in the arm, and then reinstall the bolt, and nut. Safety feature so if bolt comes loose, pedal shafts won't just slide throught the arms, and go to the floor. The bolt in mine is in the upper-most notch on the clutch pedal, meaning it can only be adjusted for a higher pedal, not lower. You could probably take it out, make a nother notch, and put it back in.
rustystud
3,390
Woodinville, Washington
That's interesting. Mine doesn't have that, it's just a straight shaft and the bolt clamps the housing.
