MP2225 Transfer cases
kfrosty
Belmont, NC
It's hard to find these and I just happened across 3 of them. They have connections for glycol cooling. Just curious as to what they are worth. I have 4 of them now and I'm probably going to sell or trade a couple of them. Also I've got one mated to a 6.5 turbo I'm going to install. It's not an armored vehicle and I'm thinking about either capping the lines or swapping it out for a 242.
Looking for opinions on these.
Action
1,552
East Tennessee
I have it in mine, but I have no idea what they are worth. I have all the correct lines installed for the antifreeze cooling.
If you have a drivetrain with the NP2225, it would likely not have a cooling fan on the front of the engine. Does it?
kfrosty
Belmont, NC
I just have one complete drive train and then the 3 individual transfer cases. The drive train do have a fan, they are just gear driven and angled up under the radiator to my understanding.
Does your lines mount to the radiator do they come from some type of adapter off regular coolant lines?
Action
1,552
East Tennessee
That is what i meant. There is no cooling fan ON the engine. The tubes connect to the lower radiator tube and to the water crossover tube on top of engine. It also runs through my rear diff. And, yes, I also have the fan under the radiator, and the Wilwood brakes, etc. It is a 2007 REV.
BRob18E
Liberty Township, OHIO
did you get rid of all of those? I am need of a transfer case, and please don't chew me as I"m on here searching now and ran across your thread, but do you know if they will work with the 6.2? I was told those transfer case's suck and I would agree since mine is blow..
kfrosty
Belmont, NC
I assuming you're stating you have a 6.2 engine, the question is the transmission you have which is probably a 3 spd. I'm going to guess they would either mate up or there is an adapter but I'm not 100% sure.
Also, I'm not sure if you can cap the cooling lines or came up with a way to tie them into the lines on the truck.
Blake1
Minnesota
Hey bud would you sell one of the mp2225 t case
kfrosty
Belmont, NC
Frosty would you sell one of these t cases
Long story but I didn't end up with the 3 because GL BS. Anyway, I have 2 on drive trains but I'd need to replace them with NP 242's before I consider letting them go. I'm in the middle of another project right now. Send me a PM and if things change and you're still looking I'll follow up with you.
