metalworker393
- 19
- 18
- Jackson NJ
Hello and how is everyone today. I have a question for you guys ,perhaps someone can chime in and steer me to the solution.
I have the steel MRAP wheels on my Deuce, and I have I wheel that is being somewhat painful. I bought the adapter plates from peashooter all the hardware new orings and beadlocks. This tire/wheel, leaks air. I have made sure the o ring groove is clean, used BTR o ring lubricant on it , pressured it up to about 50 psi. 3 days later its almost flat.
So I took it apart twice now, used another new oring, reassembled it , pressured it up and initially, no leak. deflated it, re torqued all the nuts to 450 ft. lbs. inflated it again and installed it on the truck. 3 days later, almost flat. The only thing I haven't replaced is the air valve. Did a bubble test, no bubbles any ideas?
Now Im just throwing this out ther, but has anyone ever put a tube in these tires? Contemplating buying a rubber beadlock, drilling a hole in it and installing a tube in there . god idea, yes/no?
Thanks metalworker393
