MT654 transmission oil. Change to straight 10W
Mario
89
Rio Rancho, NM
I dropped the MT654 valve body on my 1991 M936A2.
Before I put new oil in, considering putting straight 10W vs OEM 10W40.
If my reading is any good, it appears that the HD transmission fluid is straight 10W oil, which is basically a cold version of 10W-40
I'm looking for 1st hand opinions of people that have done it and. what your results are.
Also, in googling, I did find this video from 6 years ago of an older A0 or A1 unit.
I think all the transmissions were the same, but I could wrong.
I asked question on the YT, but don't know if the IMG_0907.jpgcreator is still active.
simp5782
Feo, Fuerte y Formal
9,512
Mason, TN
Switch to ATF, specifically transynd if you want to decrease transmission temperature and increase longevity. It's cheapest from summit in Mobil.
Transmission internals are the same thruout except A2s use a different front pump and torque converter ratio.
