mtv wrecker
m35 adam
37865 seymour TN
picked up a 1994 mtv wrecker with 738 miles on it. All the fluids where drained. Filled all the fluids and the truck started right uo and drives great. I put 70 of hydraulic fluid in the tank. Says it takes 73 gallons. I filled it to the full line.
Here's the problem, The fluid pushes out of the suction filter cap. I removed the filter and 20 gallons of fluid. Now it does not spew out. Seems like a lot of return pressure to the tank?
The under reach works all 3 winch's work but the cranes does not. The turn table will spin and it trys to extend out. Something is going on with the HD system that I can not figure out. Any body know anything about how the HD system works on the wrecker. Thanks, adam
bikeman
501
Ft. Bragg, NC
The cranes are the first thing to break and the last thing to get fixed. Knew more issues with those than anything else on wreckers.
