much to my chagrin....
Awesomeness
1,523
Orlando, FL
Is this an upgrade only recommended for the 3116 or is it also a good idea for the 3126?
It's debatable whether it is a "recommended upgrade". Either design can understandably have problems after 20+ years of use, so the "recommendation" is more accurately just to check, and/or replace the line if it is suspect.
To my knowledge, there are only reports of old/original steel lines failing, so the "upgrade" is a "solution" to a problem that doesn't really exist, and introduces its own weaknesses. The steel line will flow better.
BERZERKER888
896
Daytona, FL
the more I look at the "wonky-ness" of the Grigsby install I am seriously considering installing a new OEM oil line sitting on my roll cabinet.....
87cr250r
2,137
Rodeo, Ca
I get the misfortune of racking up a lot of hours on a lot of engines. There are certainly locations that you're going to experience repeat failures. The Cats are especially prone to breaking hard lines. There have been a few cases where we solved problems using rubber hoses. Also know that Cat only recently discovered that you have to use EPDM o-rings for face seal and boss fittings used in coolant service. I always recommend OEM unless you have special knowledge of a better solution or OEM is not available.
Ronmar
8,393
Port angeles wa
Or OEM has repeatedly failed destroying engines:)
Awesomeness
1,523
Orlando, FL
But if we had 100,000 of these trucks with the soft lines, 25 years old, we'd be hearing lots of stories of "soft oil line of death" too. So it's not the technology of the line, it's just that if the line fails for any reason, you're dumping all your oil in 90 seconds.
87cr250r
2,137
Rodeo, Ca
The problem with soft lines is that theyre difficult to specify. It's especially difficult for the average Joe to make the correct selection. The hose shops don't know, either.
Back to the hard lines, I've never had one cause a failure of an engine, just shutdowns. Don't keep running it if it's pushing oil out.
An interesting story, our Cat 3500 series engines with right hand service option used to blow the o-rings annually on the main line pipe from the cooler to the filter (a 2" line, big mess). It was always a spiral fracture in the o-ring. Cat played with different brackets and never had improvement. We changed the assembly lubricant and solved the problem.
Ronmar
8,393
Port angeles wa
Yep I love hardlines, and this one would not have been an issue if they had simply added support or routed it so it was not overhung… to be fair, where hoses are specified, typically so are inspection and replacement intervals for the reasons mentioned…
87cr250r
2,137
Rodeo, Ca
I didn't mean to say we didn't have significant risk from failures of hard lines, just that one never caused the death of an engine. The above lube pipe failure I mentioned would dump 25-35 gallons of oil within an hour. It required a shutdown of the engine but didn't cause additional damage.
I am actually a hose fan but I focus on correct hose specification and application. I also understand that hoses cost more than hard piping which seems to be lost on the proponents.of hose.
GeneralDisorder
6,209
Portland, OR
The problem here is the "oil line of death" is so named because it HAS caused engine failures since it will pump the engine dry in a very short period at 2600 RPM cruising on the highway and goes unnoticed till it's too late because the leak is below and behind the operator.
