MuleMacs M561 rebuild and restoration thread.
Guyfang
27,345
Burgkunstadt, Germany
Please list this stuff in a parts wanted thread. You get better viability.
The window thumb screws 5 1/6 -24 can't find anywhere
M60 swing arm mount
New tires mine are junk just nothing on the West coast close to vegas no one lists.
Rear cargo cover
Dash control switch data plate mine is white and not bl
DotusPL
78
13
POLAND
Hello
Yes, the foam can be a problem.
Mine had been soaked in water for many years. This is causing serious corrosion.
My renovation was halted due to numerous holes. I cut open the floor from underneath and removed the foam.
I have no idea how to repair it because the aluminum oxidizes, and with so many holes, I would have to replace the entire paneling.
I'm wondering if I should repair it from the inside with aluminum glue... a serious problem I haven't solved.
The photo shows water leaking from the foam after sandblasting the trailer.20210629_131013.jpg
MuleMac01
Military vehicle collector
197
Las Vegas Nevada
B
Hello
The photo shows water leaking from the foam after sandblasting the trailer.View attachment 956303
But can the goat hold water in the tub under the foam. If it's not corroded?
