I have some of these available:
The Space Heater Arctic (SHA) is a lightweight, portable, multi-fueled, non-powered heater intended to heat five and ten man arctic tents. Provides a maximum heat output of 28K BTU with a high/low adjustment capability. The SHA replaces the current Yukon heater, which has severe operational deficiencies and poses a serious safety hazard in the field. The SHA operates without the use of electrical power and can burn all types of liquid fuel (DF-2, DF-1, DF-A, JP-5, JP-
and solid fuel (wood and coal). The SHA utilizes the new vaporizing S-tube burner technology that overcomes the major combustion and safety problems that have existed over the past 50 years in the nonpowered heater industry. These problems include poor smoky combustion of diesel fuel and the hazardous exposure of a pool of raw fuel during operation. The new vaporizing S-tube burner technology eliminates these deficiencies while still maintaining simplicity, ruggedness, and low cost.
The NSN for the
Space Heater Arctic (SHA) is 4520-01-444-2375. The cost is around $700 including all accessories.
Description:
The SHA measures 17" H times 9" W times 17" L and weighs 41 lbs, including all accessories. These accessories are comprised of the stack, flue cap, gravity feed adapter, fuel can stand and hoses. All accessory components, including the pre-assembled, telescoping stove pipe, can be stored within the heater making it highly mobile and easy to assemble. The SHA is operational in temperatures ranging from minus 60° F to 60° F, and can be stored in temperatures ranging from minus 60° F to 160° F.
