Multifuel eng oil pan
Boatcarpenter
Marlborough, NH
Also, I understand that if you jack the frame up so the front suspension hangs as much as possible it makes it easier to get the pan out. Haven't tried it myself but it sounds reasonable.
BC
Stretch44875
Super Jr. Moderator
Tiro, Ohio
Yep, pulled two of them. Helps as Boat said, jacking the frame up and letting the front tires and axle drop helps. Pretty quick job.
