seaaggie
- 0
- 1
- Austin, TX
I have an oil leak at the oil tube enters the engine block on my multifuel. Someone told me to just tighten up the nit but if that didn't resolve it there was an o-ring inside that may need replacing. After trying to tighten the nut, and not making any movement, I took the tube off and inspected it. Both ends appear to be compression fitted and aren't cracked or otherwise damaged. It was never my experience that a compression fitting used any o-ring at all. I always thought the idea of a compression fitting was that the more pressure applied by the nut the better the seal.
Does this really use an o-ring?
