Rattlehead
- 3
- 18
- Michigan
I've seen a lot of various posts, equally divided with some saying their truck is very hard to warm up, and others saying theirs runs up pretty good to 180. Well my deuce has always stayed on the cold side, around 160F, unless I had the cover buttoned up good and was on the highway and in warmer weather, but then you had to babysit it with the cover and/or flap.
I know diesels don't warm up well unless they are loaded. Still, I kept thinking the thermostat must be stuck open or something. However, upon looking at a t-stat out of the engine, it didn't seem like it would be prone to do so. Ordered a new one recently, finally put it in tonight. When I removed it, I looked for how it could be sticking, scratching my head, then I finally noticed that its marked as a 160, whereas the new one is a 180. Duhh, well it was working as designed!
What application would want to run a 160? And I don't believe that sticking in an earlier opening t-stat helps keep an engine cool, as many hot rodders do. After all, whether it opens at 160 or 180, there better be enough radiator capacity to hold it there once it opens or theres another underlying problem.
Anyhow, the 180 is in, and hopefully the multi will be happier running where it is designed to run. I know I will be happier not having to babysit the winterfront cover so much.
Pic didn't turn out in the 160 stamping, but I am posting the t-stat and housing pics just for reference for those who haven't opened one up yet. There is a rubber seal that the t-stat body rides in, and separates the bypass circuit from the full flow circuit. Though there's a big flow path right through the center of the t-stat when it is in the closed position.
