Oerthedge21
- 20
- 18
- Northford CT
So after weeks of the kit sitting in my room I finally got around to installing it. For those unfamiliar, this kit converts the truck to a pair of spin on fuel filters, like the jatonka kit except I believe this a far better setup. This kit comes with all new fuel lines from the tank to the IP and a new filter bracket. With this kit you take out your old feed line, and the primary and secondary fuel filter bases. The new setup bolts into where the old secondaries went. The instructions were great, they included pictures too. Overall I would absolutely recommend this kit to anyone who wants to do it, installation was almost flawless, though I did have to modify two of the fittings. I believe it was designed for non winch trucks as the fittings that go under the IP don't clear the driveshaft. But all I did was cut the fittings off and use the hose barb fittings I already had on my old system. I also had to cut the fittings that connected the kit to the fuel return line, the fittings weren't quite the same, though my truck has been through a few people so my fitting may not have been original. Once again easy fix, just cut the old return line off the barb where it hooks up to the hard line at the frame rail, and used a piece of 3/8 fuel line from the kit fitting in the regulator T to the return hardline. I highly recommend this kit to anyone, I had asked about it a while back but nobody knew much. I had a few people message me asking about how it went after I bought the kit, but I had no answers since I hadn't installed it yet, so I figured a thread post would be a good way to spread the word. After the install my truck definitely runs better, the egts are up a bit and it has a little more power. Plus now you can run a much better fuel filter and a water separator for maximum fuel quality. The kit comes with a chart if all filters that for the filter mounts too. Here's a few pictures of the final product. I have completely removed the entirety of the stock fuel system, all fuel lines and all three filter canisters. Feel free to ask me if you have any questions.
