LMRmopar
- 118
- 28
- Alberta, Canada
Now begins the fun process of it all, I have taken lots of photos for those curious as there isn't exactly a whole lot of information on the H110..
The Eaton/GM H110 was a 12.25" Axle used from the 1940s-1980s, from deuces to one tons. (Last known use was 1986 Chevrolet C30). They're all open diffs as far as I know.
Parts are getting harder to track down but thankfully the bearings are still being produced in limited numbers, they are expensive however...
Pinion Seal: 25970 (SKF Number)
Outer Pinion Bearing P/N: 5310WA (SKF Number)
Inner Pinion Bearing P/N: MU-1306-TDM (BCA Bearings)
Differential Side Bearings P/N: KA11820-Z (SKF number)
Locker Assembly: 250S27 (Detroit No-Spin)
As for gaskets I am sure I could have tracked down them all however I much prefer to use High performance Engine Sealant as we have an abundance of it at the shop LoL.
The service procedure can be found in the technical manuals and does go in depth with a lot of it, however it should be noted that this differential shares nothing with todays differential configurations.
The pinion has no shims and no crush sleeve, seeming as both pinion bearings are ball/cylindrical roller bearings, the need for a crush sleeve is moot. The pinion nut is torqued between 160-280 Ft-Lbs.
This Diff has what is called a Thrust Block and keeps the ring gear from flexing too much when under severe load (This must be removed before attempting to remove the ring gear/diff carrier from the axle)
