My 416 is stuck in 4th gear. Suggestions?
Karl kostman
917
Fargo ND
If you have already tried all the movements in the shift lever and still nothing I would then get under neath and start looking at linkages looing all all the contact points for rust or zero lubrication. I would then have someone in the cab moving the shift lever again looing for any binding in any of the linkages. If that fails then I would pull the top off the transmission and have a look inside and check the top out good while you have it off again looking for binding, zero lubrication broken pieces etc.
Good luck it cant be that difficult to figure out!
