jd-ford-hd
- 0
- 16
- Manchester, TN
Here is a pictorial of my 5 ton single tire project. I took my six old and shabby looking wheels to a tire store near here who has a wheel refurbish shop. It is an automated bead blast and powder coat line. They at first quoted $20.00 a wheel but found the CARC so tough that they had to run the wheels six times to get the paint off. Wound up costing me $50.00 a wheel which I still consider a bargain because of the super job they did. The powder coat they do is white, gray or black only, so I chose the black. The tires are 395 85 20's that were purchased from GL. I bid on these Goodyears like they were very good used, but when I got to Lousiana I found every single one in my lot were brand new unused!!* My next post will hopefully show the completed install on the truck.
My wheels looked like this
Back from the refurb shop
Cargo net used to keep wheels off concrete
6 new air valves and orings
Air valve installed
Thread chaser to clean paint from threads
Compress bead lock ring with ratchet strap
Two tire irons to spread bead so lock ring can be tapped into tire
When lock ring drops in release strap and center in tire
Now tire beads and bead lock are ready for lubing
To be continued.............................!!!
Air valve installed
