My ABS system finally works
army_nurse
Fort Gibson Oklahoma
Much like many other members here my M923 ABS light was on constantly. I had been checking the system and reading the TM's. I found the 2B cable was disconnected. After several attempts to get it to snap together it finally clicked together. So I went through the entire system and cleaned and treated all the connections with anti corrosive lube/cleaner. After that the system light continued to be on constantly. I took the truck to Walmart today, due to the ice and sleet here today, and had to get on the brakes pretty hard due to a short stop light. After that the ABS light went off. I thought I had blown a fuse. However, after shutting the truck off and then restarting it after I was done in the store, it self tested and the light went off. All the time I spent trying to fix it and it was an unplugged wire. At least it was an easy fix.
M35A2-AZ
384
Tonopah, AZ
That is good news on the ABS light. I have one that it is on, you can hear the relays do there thing but the light stays on. May have to give the brake thing a try.
Be safe on the roads and stay warm!!!
army_nurse
Mine did the same thing. You would hear a series of clicks but the light would not go off. I am glad it was an easy fix after all was said and done. You might trying to clean and then plug back the connections. It might be worth a try.
mahdey
Ft. Knox KY
do these trucks have a j1708 or older data port connection on them? What I a asking is, can I hook up my computer to read ABS codes like I can on Medium duty/Heavy Duty trucks?
M35A2-AZ
384
Tonopah, AZ
I have done a little trouble shooting and cleaning on it.
It was working fine then it stopped going off.
Thanks!!!
army_nurse
They have a diagnostic port on the passengers side. The nomenclature of the port I am unsure. I think Haldex makes a diagnostic reader for the system. It may or may not be comparable with your system. There are several members here with more knowledge than I. Maybe one of them will chime in soon.
