my deuce gets an M60 ring.
sermis
17
Temple, TX
Need help locating a pic. I know I saw where someone had a hard top and it had an access hole for the gun mount. Can't find it, anybody know where it is?. I am thinking about adding an access to mine. But I still want a soft top..........
FreightTrain
Banned
2,730
13
Gadsden,Al
Saw several on GL that had the holes.Couple looked like a standard hard top with a hole cut in it.They cut the top off a 55 gallon drum and welded it into the hole on the roof.Guess you would remove the lid when you thought you was going to need teh MG and leave it on when in the Motor pool or on safe drill.
hndrsonj
Senior Chief/Moderator
359
Cheyenne, WY
It isn't an official mod. It would be very easy though. Like it was said get the lid from a 55 gallon drum, cut out the lip, weld it on to give the edges of the hole rigidity (and not sharp), then cut out a circle about 2" oversize, rivet on some stringers for rigidity then use camlocks to put the cover on. :wink:
FreightTrain
Banned
2,730
13
Gadsden,Al
The one I saw had some of the drum inside the cab but the 2 inches or so finger cut and folded over so it formed a flange of sorts then welded in place.
86
Romeo, Michigan
I was lucky and bought a brand new ring mount in the crate at Aberdeen 2 years ago. Got home Saturday night and started installation the next morning at 8 oclock. Had ring mounted completely by 12:30pm. Kit had complete instructions and every bolt and fitting was there. We mounted a block and tackle in a big tree and used our tractor to lift the ring up. We then drove the truck underneath. I got a metal replica of an M2 that everyone thinks is real. It was made by a guy in Richmond Michigan.
jwaller
20
Columbia, SC
do you have his info? I have been looking for a good replica myself.
