- 4,616
- 4,627
- 113
- Brentwood, Calif
Just an FYI.....MT series Tires are non-Directional, They can be installed either way.
It just looks better when the tread pattern matches
You can go backwards REALLY well.Jimmy said:Ask a farmer what happens when you turn the tread pattern backwards.
Thanks for the detailed info Kevin.decodeme2 said:Hey Bart,
The axtra armor/ bolts are inside the front fenders to protect the engine, under the door sills, under the hood rubber tie downs, bolted to the inside of the tail gate, and inside the wheels wells to protect the cargo area. If you feel inside these areas you will see extra 1/4 steel plates. This is why they are called up-Armored Hmmwvs. Also dont forget the doors if you haver them..Hope this helps..
Kevin..
The MTs I have on my D60s are directional. Granted they are a different size, but they are the same tread and have the rotational direction clearly marked on the sidewall.TheHummerguy said:Just an FYI.....MT series Tires are non-Directional, They can be installed either way.
Jimmy said:You can always put two one way and two on the other and go in circles real well. LOL
TedG said:I agree emmado22 for all the new mounted tires I have seen are mount on the rim the same way. Simple.
Interesting note: On my unimog 406's manual, they want the front tires to be "backwards" for off road work. Since the mog has lockers at the axels, it provides similar traction for forward and backward operation...ie getting stuck. As you can see on my mog, I had a brain fart and put the rr on the rf and the rf on the rr when doing a brake inspection...
Again, nice truck Bart and as long as your happy with your truck, do what you want! PS. offer still good on test driving here in the States prior to be containerized!!!
Regards,
Indeed Ted, its a mouthwatering piceTedG said:Bart,
I sure would like to walk that field of hmmwv's for they are A2's!!! The type I am currently building. Boy, a LOT of my questions would get answered what goes where!
Seeya Bart.
