My final m1028 project
CPAPPY
Xenia , Ohio
Here are so pictures of my build project . Truck bed has one coat of epoxy primer on it, doors ,fenders and hood have all body work done to them and ready for epoxy primer. Thinking about removing cab to paint the frame . It looks like it would be a lot of work .
jimmy-90
Haymarket Va.
I like the tall skinny Michelins. Looks like your gonna need a little bit of lift or some pretty radical fender trimming in order to put the bed and fenders back on though. I would love to run a set of those some day. Those look to be at least 38 or so inches tall. How much lift do you think it would take to run those without any fender trimming? Also that truck looks good all taken apart and is probly gonna look great when it is put back together.
CPAPPY
Xenia , Ohio
Thanks , I have a 8 " lift for it and crossover steering . I didnt want to cut the fenders in case I want to sell the truck and put on some stock tires on it . Might put on a set of Nitto mud Grappler 38x15.5x17 If the tire look to skinny .
CPAPPY
Xenia , Ohio
Disassembled
Finally today I did some work . Epoxy primered the cab , and pulled the cab off . Will pull the motor to clean up , put on thicker head gasket for the turbo , new hose and coolant gasket . Is there anything else I should do before putting the motor back in . I will also be painting the frame and will be putting on a lift kit and crossover steering .
CPAPPY
Xenia , Ohio
Painted frame
Want to show more picture of the frame. All I know is it takes a long time to clean, also pulled engine and wanting on a re-ring set thats on backorder.
Remove transmission to find out why the parking pawl is not holding , when I recieved the truck there was no parking pawl assy. in there, so I bought one and put it in and it willnot hold on a slight incline . Any suggestion on what might be wrong , all it does is just click. Also rolling backwards there is less holding .
CPAPPY
Xenia , Ohio
transmission fix.
Took off transmission pan looked at the assy. and found out I had the top bracket rotated 180 deg. out now it engages into the gear . The assy. shown now is correct.
BobM
Fillmore, Indiana
Glad it was so simple. But, if you are like me, you wish you'd done it right the 1st time!;)
Been there done that. Skipped the shirt!
CPAPPY
Xenia , Ohio
At least It I had the tranny out , So much easier and cleaner out . I am glad it was so easy to fix , I was worried it would be something else.
CPAPPY
Xenia , Ohio
Well today I finished installing motor , And installed a 8"front lift and a 6" rear lift springs are from Superlift . Still need to and my extended brake line . It still seem to be sitting high in the rear about a 1.5 "taller. Now I need to calc. the pinion angle to shim correct. Never done this before but have read up on how to. Still waiting on some info. on pre filter before electric fuel pump .
