my first oil change
emmado22
168
Mid Hudson Valley NY
Just got back from the warehouse.. I let the deuce run at idle for 1 hour to get the oil and sludge moving. Then drained the oil, then removed filters. Oil wasnt burnt, no smell of fuel, no metal fragments, so I think Im OK. It's still draining, then I'll put filters on, and oil in tommorrow...
Anything Im missing or forgot to do?
Also, FYI when draining the pan, use a 5 gallon bucket, not a 5 gallon water cooler jug with funnel..... Dont ask me how I know.....
acetomatoco
9
It is interesting that sometimes 25 quarts will not fit in a 5 gallon bucket... did you drain both sumps?
3,157
Tip#2...Don't let the cans turn when you install them, they cut the gasket...ask me how I know...and torque the bolts or they will leak...see above. Just curoius, after the change, see how long it takes for oil pressure to come up.
emmado22
168
Yes I drained both sumps, rear first. I cleaned the outside of the canisters/base to get the crud off.
I'll make sure not to have the canisters turn, I've seen leakers when they do.
Will report back tommorrow.
Next project... Cooling system...................
Thanks!
jwaller
19
Columbia, SC
I changed my oil the other day and all was well even went for a 250 mile drive. got in the truck this am to go to the store and I dumped about 2 gallons in the street before I recognized that I had a huge leak. Somehow the Oring got sucked back into the can after shutdown yesterday. Went to napa today and got a new filter and seal and all seems well. We'll see tomorrow if it leaks again. this time it's parked on dirt so if she leaks again my neighbors wont get he bad end of the deal again.
OPCOM
29
Dallas, Texas
Mine will be changed soon, and before I do, I will sample the oil via the convenient oil sampling valve on the oil filter base assy. and send it for analysis. Before changing it I am waiting for the prelube kit and the oil filter adapters kit. No rush, only 1800 miles on the current batch of oil.
