- 43
- 15
- 8
- Theodore, Alabama
Thank you!
235/85 R16. I'm not planning on going any bigger. One of these days, I'm hoping to swap transmissions to something that will help on the highway speeds. I just haven't figured out what will be my best option yet. Also, currently in the works is a Banks turbo.Seeing your rekindles the fire. What size tires did you use? Looks great.
That is one of the most common problems after rebuilding the "Top End" of an engine especially after adding a "Turbo" . You've returned the engine to stock compression or beyond (with the Turbo) and now the old rings cannot handle the pressure.It's been a while since I've updated on here... Got the Banks turbo installed, head studs, and pretty much rebuilt the top end. With so few miles on the odometer, I didn't think anything needed to be done to the bottom end of the motor.... Boy was I wrong!!!! She was pulling up and over the mountains in West Virginia wonderfully for about 250 miles. Then, BAM..... Broke a ring!!!!
She will live again, and I'll continue her build!
Exactly.... I'm not brave enough to put a turbo on my 6.2. I'll just leave it the way it is...That is one of the most common problems after rebuilding the "Top End" of an engine especially after adding a "Turbo" . You've returned the engine to stock compression or beyond (with the Turbo) and now the old rings cannot handle the pressure.
Very probably. At the transit department we used to use "brake clean" spray to get the old Detroits to fire off in winter. Spray some on a rag and hold it by the air cleaner intake. They would fire right off, but later in the summer they would start to burn oil really bad. So we would have to replace the rings or just put a whole new "jug" in it.Well boosting will reveal any bad parts. But the way I see it their just that, bad parts that would have failed anywayI installed the banks turbo at around 30,000 miles. It ran fine for about 20,000 miles till the head gaskets let go. But then any 30+ year old 6.2 is going to need head gaskets. I would imagine the broken ring issue experienced by boats, was from abuse of the previous owner, perhaps using starting fluid?
Never heard of that before! It wouldn't work with todays 'safe' non flammable brake cleaner, my how time have changed. BTW are you referring to the old Detroit 2 stroke?Very probably. At the transit department we used to use "brake clean" spray to get the old Detroits to fire off in winter. Spray some on a rag and hold it by the air cleaner intake. They would fire right off, but later in the summer they would start to burn oil really bad. So we would have to replace the rings or just put a whole new "jug" in it.
Yes, the good old 6V92 .Never heard of that before! It wouldn't work with todays 'safe' non flammable brake cleaner, my how time have changed. BTW are you referring to the old Detroit 2 stroke?
