booger
- 2
- 18
I think your right
Ummm....correct me if I'm wrong but doesn't the compressor belt just run down to the crank pulley and the alternator belt run around the crank and water pump pulley? I would put a digital volt meter on the alternator output and see what the voltage is when the dash needle pegs. It sounds like you're losing your ground for your alternator and its basically full fielding the alternator and will eventually fail.
regulators are available new from Erik's mil surplus.
You may have a bad connection or cable. I would measure each cable for resistance before replacing the regulator.
For some reason when my air compresor runs my voltage surges and all my light get brighter. It will go away as soon as the compressor shuts off. Any ideas?
