lonesouth
- 29
- 28
- Tallahassee, FL
affirmative, 15w40.
gauge read low.
so, did you know that these things will crank and run with low coolant? What I thought was the coolant line on the overflow bottle...that was just a stain. I was able to pour at least a half gallon into the radiator, and then more into the overflow bottle. When I got these, both were running and the GP rep stated that he changed fluids. I changed the oil when I got it, and "checked" the coolant, obviously not well enough. The temp gauge never read hot, always stayed below 180. I've had it running now for 30 and the temp is just under 200. Oil pressure is still just above 40psi.
So here is my theory on what happened. With the coolant low, the temp sender and over temp switch were not immersed in the coolant. The heat transmitted through the block was enough to make the temp gauge register something, but not enough to show hot, nor trip overtemp fault. As a result of running hot, suspect really hot, but not enough to seize, the oil thinned so much that there wasn't enough pressure. This, fortunately, tripped the low oil pressure fault before the engine seized.
gauge read low.
