Here is the radiator cap for that unit..
Stant 10228 Radiator Cap - 7 PSI
I had to order off amazon. My local parts store did not have anything like that.
Thanks for that. It is showing in stock at all the Advance and Carquest parts houses here.
I will probably take you up on that for the first go. Thanks!leave bonding strap in place until you hook it to the house or to a panel that is bonded. If you like, I have a breaker box already wired with breakers and wire for load testing. Welcome to borrow it.
Yep tried moving both several times.For the voltage meter issue exercise both the AM-VM switch AND the voltage reconnection switch inside the control box. Both control power sent to the voltmeter.
