my modified m882 project
Hoot_223
Im in the process of taking my shortened m880, and putting a 6.2 litre diesel engine and a 4 speed. with a np205 transfercase.
i will be taking pictures of it all soon.
Elwenil
40
Covington, VA
A GM engine in a Mopar?!?!? Blasphemy!
On a similar note, I am currently building a '88 Ramcharger to mil-spec. It's a factory 4 speed, 318 and I swapped in front and rear D60s with 4.10s and a NP205. Soon it will get a M880 BO lamp kit and a 3 color NATO paint job and eventually some HMMWV rims.
Elwenil
40
Covington, VA
I will post some pics when I get a chance. I think I posted a couple pics just as I was starting the axle swap in the Member's Rides section. It looks a little different with the stock 16" steel rims and the big hubs sticking out. Sits up a little higher also. I still have to do a little work on the 205 shifter. The 205 bolted up perfectly where the 241 was, but the floor is apparently slightly different in the '88 Ramcharger than it was in the '81 W250 parts truck as I don't have enough travel to get into 4 Hi. I should be about to trim about 1/2" out of the rod and re-weld it to get access to all the gears. Then the rust repair will begin with a lot of the rocker areas getting replaced with heavy steel, integral rock sliders.
Basically it's a Ramcharger that is heavily influenced by the M880, GM CUCVs and the HMMWV. Should be interesting anyway and decently capable offroad.
maddawg308
825
Appomattox, VA
Put a M880 grille on that Ramcharger, and it will look more original, Lanty! Sounds like a great project.
Elwenil
40
Covington, VA
I had thought about that, Mike, but since the body lines are obviously an '80s model I figured I'd go with a "what if" type of vehicle as if Dodge had kept the CUCV contract instead of GM getting it. The '88 grille will stay and will be notched for the BO lamp, per M880 specs. I may never get as far with it as I plan, but time and wallet willing, I'll have something a little different than a normal MV or civilian Ramcharger. Sort of a blend of Soni Honneger's War Wagon, a CUCV, a M880, and a HMMWV with a civilian Ramcharger.
Hoot_223
my truck is now in the process of being reassembled, i will post more pics soon and some video of it running
pa.rich
Re: RE: my modified m882 project
Yes, A GMC engine deserves better! :lol:
