My new project
Jimmy
Louisville, TN
The bed on my Deuce was pretty rusty so I bought a new style drop side one but it was too long for the frame so a friend of mine helped me stretch the axles to make it look right and carry a load better. Then I had to make a frame extension for everything to fit back into place. All I need now is a repaint.
Jones
Sacramento, California
First-rate job!! Makes your truck look a lot better when things are more in proportion.
Great looking shop too; sure beats working in my driveway.
jeli
Stillwater, MN
Would this make it an M35.5 or deuce and three quarters? Good job. How did the move go? What type of fasteners did you use?
Jimmy
Louisville, TN
Thanks for the comments. The shop is a definate perk and makes the big jobs much easier. I used grade 8 bolts throughout and with reinforceing the frame it should be as strong or stronger than before. I thought it was a 5 ton bed as well but I measured my 5 ton and the frame rails are much wider but are actually the same on the deuce. So I thought it was off of a 900 series truck? really not sure. I guess it would be a deuce and three quarters now, I hadn't thought about it.
halftrack
13
New Orleans, LA
That is a Marine Corps 5 ton bed used on both 900 and 800 series trucks. The Marines switched all of thier 5 tons to this type of bed in order to put ISO type containers on them because of thier unique latching type system. I've been in the Marines for 12 yrs and I believe it is a Marine specific bed. I never seen any Army trucks with that type of bed.
steelsoldiers
4,101
Charleston, WV
Good call Jason. My Navy M923A2 has the standard 5-ton bed Jimmy, but I have seen Marine Corps 939-series trucks with the ISO beds.
Jimmy
Louisville, TN
Thanks for the info, it is good to know. It is a really neat bed where the sides can lay down or come off and slide up inside the back for storage and it also has storage places built in for the bows and brackets. You can have a clean flat bed without any trouble or a troop carrier or carry your ISO container around. Whoever designed this bed did a great job.
PWM
Saint Maries, Idaho
Jimmy your truck looks great. With the rear axles slid back you could switch from the bed to a fifth wheel and back to the bed if you needed, kind of a multi purpose truck. You could build a set of removable bed jacks like on a camper to remove the bed. Just one of the crazy ideas I have had for my truck. Are your rear tires grooved, or did someone go crazy with a yellow crayon, I can’t tell. I have been thinking of grooving a set of tires to see if it helps traction.
Pete
builder77
I think you need some bigger tires to keep the proportions right. Looks like you did some nice work on it.
Jimmy
Louisville, TN
Pete,
Yes, all my tires a grooved, it does help with traction and looks cool to. I have a buddy that is into tractor pulling and all he talks about is grooving tires and how he can cheat and get away with it, LOL.
Ethan,
Yes, it would look better with bigger tires. Super Singles are on the way as soon as the money loosens up a little around here.
Thanks for all the nice comments everyone!
Jimmy
Louisville, TN
When I do the repaint they will get a coat as well but they arn't white they are desert tan, that doesn't make them look any better though.
Armada
Buick City, MI
Very nice work! It looks like it belongs there. With all that new cargo room to fill now, the trips to the Home Depot just got longer! ;)
