My new purchase (M49)
Jim Hunter
Hello guys,
Today I was struck a deal and bought my first US Army truck.A M49 w/gas 6 cylinder engine.
Truck has some years to start and I need your advice to what I have to do ?
Also anyone can please let me know the specs of the required batteries please ?
Thank you,
Jim
Maverick1701
181
Lubbock, TX
Good save sir! I would say find the batteries with the highest cold cranking amps (That will fit in the battery box) and drop them in. The stock 6tl military batteries are expensive...
gunboy1656
22
Beaver Falls, PA
I might be off, but that looks more like an M50 water truck, then the M49 fuel truck. Either way still looks good. any pics of the other toys they have?
I have family that is from Greece, they moved here for a while but then went back.
cattlerepairman
3,201
NORTH (Canada)
The good news is that the sheet metal appears to be decent and most things seem to be there. The turn signals are nice, early style ones and probably original.
Good luck with the restauration!
Picture 4, to the left, that is a Mercedes G wagen sitting on its brakes there...:cookoo:
joeM62
Cedartown/GA.
All you need is 2 batteries that have the same cranking amp I used 2 that were
putting out 500 cranking amps each it did good in the duce.
hndrsonj
Senior Chief/Moderator
362
Cheyenne, WY
It's a M49. WM, If it's a gasser some stuff has been changed. The drivers side tool box is from an early gasser. Notice the drivers side windshield is newer, where the passenger side one is from an early gasser that belongs on the drivers side. I like the gasser/427 rear exhaust. Good looking truck, nice save.:beer:
Jim Hunter
I am glad you like my small truck guys !
Any idea about the production year of the M49 ?
Also do these trucks have air brakes ? If not possibly it has a leak as the pedal has no pressure at all.Where is the M/C located ?
Thank you,
Jim
Tomorrow in the yard again with more pics!
Barrman
1,699
Giddings, Texas
The engine is a REO OA-331. Called the Gold Comet. Not much battery is needed to turn it over compared to a diesel. A matched set of something is best. If all you are trying to do is fire it up and move it. Then just any pair will work.
The brakes are hydraulic drum at all 6 corners with air assist. The master is under the little hatch in front of the drivers seat and to the left of the tunnel. You will need a 3/8" wrench to remove the vent line and a 3/4" to remove the cap. Plan on holding a flash light in your teeth as you wedge yourself between the seat and steering wheel to look down into the master. You don't need air to stop at all, so the pedal should be solid and good with no air in the system.
The sheet metal is 1952 or earlier for the cab/fenders/running boards. I don't know enough about the tank part to even comment. What does the data plate on the passenger side of the dash say?
Jim Hunter
Thanlks Barrman for the info... and all the guys for their help..
Today I was remove the gas tank.I really shot and I need to find another one.
Missing are the mirrors , windshield wiper blades , cab top cover,horn button
I am wonder if there is NOS carbs available ?
Also these era trucks didn't have high / low ?
Rgds,
Jim
Barrman
1,699
Giddings, Texas
There is a high and low for the transfer case. That is the lever between the seat and the transmission shifter. Engagement of the front axle is automatic through the way the transfer case works.
cattlerepairman
3,201
NORTH (Canada)
Jim Hunter, you may have seen that all manuals that you could ever want or need for these trucks are available for download from this site. If you do not want to spend the time, they are often on eBay, on a CD.
You will find that operating and restoring is a lot easier with the right manual.
123mack
11
Jemison, AL
As far as I can tell, the manuals on this site are not accessable at this time. Also,judging from the grammar in Jim's posts, I would say English is not his native language, so let's cut him a little slack.
3dAngus
101
Perry, Ga.
What is that M37 looking truck in pic 2. Not a M37, but it sure looks good and looks like it is being used.
