My "new to me" 1997 M1102. (Question about correct rivets)
Ric_m1102
Richmond
Hello, I recently purchased a 1997 M1102 from a private party. It came with the cover, hoops, and mounts, but the cover was trashed, so I replaced it with a new green cover from https://www.easternsurplus.net/. I also purchased new (old stock) shocks and reflectors from https://www.easternsurplus.net/. Additionally I purchased three unused 2018 BFGoodrich Baja tires from https://csmarmytires.com/ and three wheels from http://www.trailworthyfab.com. I'm very happy with the products and service from all three companies.
I mounted all three tires, installed the shocks, and undercoated using "Fluid Film" which I've used on my 3/4 ton Pickup. The trailer had some surface rust, but it's still solid. I also purchased 10mm rivnuts and replaced many of these for the cover mount attachment points. Also found a 7 pin connector on Ebay and replaced the NATO connector. All of these maintenance procedures went well. The previous owner had already changed it to a 12 volt LED system.
Question: Can anybody identify a source for the correct rivets used on this trailer? I need to replace the reflector covers with the parts from Eastern. Thanks!
Random photos below:
Guyfang
27,160
Burgkunstadt, Germany
For the reflectors.
NSN: 5320-01-414-2171 Part #: BAPK-69, RIVET,BLIND .198 DIA X .562-.575 4
GRIP................................
FASTENER LENGTH1 3/40 INCHES MINIMUM AND 1 23/200 INCHES MAXIMUM
HEAD STYLEUNIVERSAL
HEAD HEIGHT0 97/500 INCHES NOMINAL
SHANK DIAMETER0 193/1000 INCHES MINIMUM AND 203/1000 INCHES MAXIMUM
HEAD MAJOR DIAMETER0 43/100 INCHES MINIMUM AND 23/50 INCHES MAXIMUM
EXPANSION DEVICEPLAIN STEM-TYPE T
GRIP LENGTH0 281/500 INCHES MINIMUM AND 23/40 INCHES MAXIMUM
MINIMUM TENSILE STRENGTH380 POUNDS PER SQUARE INCH
SHEAR STRENGTH292 SINGLE POUNDS PER SQUARE INCH
MATERIALALUMINUM ALLOY 2024 MANDREL OR ALUMINUM ALLOY 5056 MANDREL
MATERIALALUMINUM ALLOY 5056 BODY
SPECIFICATION/STANDARD DATA19207-12449400 MANUFACTURERS SPECIFICATION CONTROL
Ric_m1102
Richmond
For the reflectors.
HEAD STYLEUNIVERSAL
Thanks @Guyfang, @Zed254, and @Mullaney for this information! I'll review these details and let you know how the build progresses.
20,762
@Guyfang was the solution to finding the numbers.
He knows how to make a number hunting quest go really easy for the rest of us!
Glad you have what you needed.
