lino
- 2
- 18
- Wake Forest, NC
This would figure, but at least what I have is in good shape. Since I can't replace all the seals...
So, the back story:
1988 USAF deuce. Dual circuit brakes. Two long airpacks. One has broken mounting stem.
Decided to source 2 short ones (used) and rebuild. Then replace both long ones with shorts (while I'm replacing the MC also).
Got the two off ebay from a guy who has been selling brake systems pulled off A3s out in Florida. I just bought the airpacks, not the whole deal.
Got them and the externally were in good shape. Aside from a poorly converted (or originally installed) air-side brake light switch that stripped the pipe threads in the airpack housing... But I can fix that (barely).
When I opened them, they were very nice. No corrosion, lots of clean original grease. Only issue was that one of the brake fluid bores had a little rust. Water in brake fluid presumably.
Since I purchased two rebuild kits, I decided to rebuild both anyway.
I honed the small bores and that worked well. Then I honed the large bores, just for good measure, even though they were clean and original. They were also wavy. The hone pointed this out quickly.
These are pics after 15 minutes of honing. The black streaks are the "valleys" that the hone can't reach.
Anyway, based on gut feel, I think the bores will be OK.
So I started cleaning the silicone grease off the parts and identifying the new parts from the rebuild kit and where they go. And I found a mis-match.
All the short airpack pics that I've seen on this site have a one piece "upper piston" that looks like this (pulled from other threads)
The seal in the rebuild kit is sized to fit around the lower, large diameter.
Mine on the other hand are 2 pieces, and look like this:
So, where the one piece have a single seal, I have an o-ring (on the larger ring) and a wiper seal on the smaller part. I believe only the inner part moves.
No seal or o-ring for those in the kit. Also appears that this airpack activates the air-assist sooner, but at higher line pressure? Due to smaller piston diameter.
Anyway, the seals look usable, so I'll carry on.
Just wanted to share with others that there appears to be 2 variants of the small airpack.
Getting ready to get started, though I decided to strip paint off all parts since this pic.
So, the back story:
