B-Dog
- 293
- 63
- Denver, CO
Just about any automotive style 4/5 pin 30/40a relay should work. Here are the ones that I used for a tad less money:
24v:
12v
Spankybear is correct, without a flyback diode, the coil will generate some voltage on discharge . I'm no electrician but the only instance I personally ever witnessed that as a problem was on a solenoid (much larger coil than a relay) and the voltage bounce was sending my PLC multiple inputs. I'd be floored if anything in these trucks could be effected by such a thing, especially an A0. But, if the factory engineers spec'd a diode then who am I to say otherwise?
24v:
12v
